Yesterday's Tractor Co. We Have the Tractor Parts You Need
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
oliver1850t are you out there ? 2 speed removal question
horsinaround
02-02-2014 12:32:26
71.184.221.221
Oliver1850t I ran across a thread awhile back were you said you removed the 2 speed from your 1850. You said you got a 2150 shaft from Brad at maibachs. Did a 2150 not use a 2 speed so they had a factory delete shaft ? Or is it a 2 speed delete shaft for a 2150 ? Also what did you do at the clutch housing were it would normally bolt up to the 2 speed ? Make a plate and bolt up a flanged bearing ?
Any info you could give me is appreciated. I have a 2-70 puller project with a 8.3 swap Iam building and am deleting the 3 speed. I picked up a 1850 perkins sae 3 clutch housing that would bolt to a over under. It would be great if I could start with a off the shelf shaft and bearing arrangement. It would save me ALOT of time.
Thank you
[Reply]   [No Email]
oliver1850t
02-03-2014 14:07:09
74.69.97.149
 Re: oliver1850t are you out there ? 2 speed removal question in reply to horsinaround, 02-02-2014 12:32:26
Let me get you some pics, Ill have something back to you tonight
[Reply]  [No Email]
Mitch Poindexter
02-02-2014 13:55:22
98.196.36.243
I have a bellhousing and a 2 speed delete from an 1850 with a Perkins if that"s what you"re looking for. Do you need pics or are you looking for the pieces themselves?
[Reply]  [No Email]
oliver1850t
02-03-2014 14:28:32
74.69.97.149
 Re: oliver1850t are you out there ? 2 speed removal question in reply to Mitch Poindexter, 02-02-2014 13:55:22
I don't run a support bearing, but I do run my PTO Drive shaft to run My hyd pump. I built a lightweight front end, steer it with a small cylinder and lines from the original steering motor. Do not have PTO but a carrier bearing on a flat plate. I use the long shaft for support of the delete shaft. I will say this shaft is twice as heavy as the factory option. I had to cut 1/2 an inch off the back of the shaft(splines) was a little too long. I am going to a slipper clutch this year, having it made so it will accept this shaft. Sorry the pics are bad, i didnt bother taking off the blanket, just reached under it.
[Reply]  [No Email]
horsinaround
02-03-2014 15:12:34
71.184.221.221
 Re: oliver1850t are you out there ? 2 speed removal question in reply to oliver1850t, 02-03-2014 14:28:32
Great thanks for the info ! I shot you a email earlier too cause I didn't know if you still go on here or not. Its better to have the info on here so it can help others.
So you used a factory 2150 shaft and just trimmed it a little ?
Do you run a single or multi disc clutch ? I am just wondering if the spline is long enough for a 2 or 3 disc clutch.
This post was edited by horsinaround at 15:16:35 02/03/14.
[Reply]  [No Email]
horsinaround
02-02-2014 14:02:55
71.184.221.221
I wasn't sure if they made a 1850 Perkins with the 2 speed delete. Pictures would be great. Is it something you would be willing to sell ? That would be what I need.
[Reply]  [No Email]
Mitch Poindexter
02-02-2014 14:55:52
98.196.36.243
 Re: oliver1850t are you out there ? 2 speed removal question in reply to horsinaround, 02-02-2014 14:02:55
I think the p/n for the clutch housing to bolt to the Perkins without a 2sp/3sp is 158659AS, I'll try to post some pics if dad can slip and slide out to the shop tonight and take some.
[Reply]  [No Email]
horsinaround
02-02-2014 15:05:40
71.184.221.221
 Re: oliver1850t are you out there ? 2 speed removal question in reply to Mitch Poindexter, 02-02-2014 14:55:52
Mitch Poindexter said: (quoted from post at 15:55:52 02/02/14) I think the p/n for the clutch housing to bolt to the Perkins without a 2sp/3sp is 158659AS, I'll try to post some pics if dad can slip and slide out to the shop tonight and take some.
That would be great.! Thank you. Would you guys consider selling the setup or are you gonna hang onto it ?
Also, I found some parts manuals online and it appears the factory 1850 o/u delete shaft is a two piece shaft with a coupler in the middle. Maybe you can use the 2150 shaft in place of the factory 2 piece ?
Thanks again !
This post was edited by horsinaround at 15:53:28 02/02/14 2 times.
[Reply]  [No Email]
Mitch Poindexter
02-02-2014 17:09:58
98.196.36.243
 Re: oliver1850t are you out there ? 2 speed removal question in reply to horsinaround, 02-02-2014 15:05:40
Here's a pic of the 2 piece shaft. Dads still looking for the housing, it may be doing double duty as a flower pot or something else at the moment. If you end up needing the setup, I'll sell it, assuming the housing hasn't walked off.
[Reply]  [No Email]
horsinaround
02-02-2014 17:29:40
71.184.221.221
 Re: oliver1850t are you out there ? 2 speed removal question in reply to Mitch Poindexter, 02-02-2014 17:09:58
Thanks for the fast pictures. I would be interested in it if you can find the housing. Like I said I would like to figure out a one piece shaft but obviously I would buy the shafts and housing from you. Let me know if it turns up.
[Reply]  [No Email]
J. Schwiebert
02-02-2014 12:49:33
209.173.169.187
A couple of things don't add up and I know my 1850 parts book is not here. The 2150 was a trunion mount so there was no delete shaft Since you are moving things around a bell housing for a 1900 thru 1950 should work as well
[Reply]  [No Email]
horsinaround
02-02-2014 13:40:16
71.184.221.221
 Re: oliver1850t are you out there ? 2 speed removal question in reply to J. Schwiebert, 02-02-2014 12:49:33
I have a sae 3 flywheel housing for my 8.3 so I can bolt it up to the 1850 Perkins over-under clutch housing. The problem I have is I would have to have a custom shaft made to delete the over-under. I would also have to make a a plate to bolt up to the back of the 1850 Perkins clutch housing and then in turn bolt a bearing to the plate to support the delete shaft.
Hopefully oliver1850t will run across this thread and set us straight with how he did his.
[Reply]  [No Email]
cobroller
02-02-2014 16:08:17
64.22.253.140
 Re: oliver1850t are you out there ? 2 speed removal question in reply to horsinaround, 02-02-2014 13:40:16
I just removed the front cover from the hydra power & bolted to the bell housing. I think the shaft & coulper are available aftermarket.
[Reply]  [No Email]
horsinaround
02-02-2014 16:21:40
71.184.221.221
 Re: oliver1850t are you out there ? 2 speed removal question in reply to cobroller, 02-02-2014 16:08:17
I didnt think of just using the o-u front cover. Good idea. Have you ran into any issues without the shaft supported were it goes thru the clutch housing ?
I would like to run a 1 piece straight shaft right to the trans so I only have one coupler. Just gotta figure out if I can use any factory parts to accomplish it.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
