Curt Courtney
I wanting to build a div I Div II puller for 4500 5500 class and these are 2 that I am considering I want to put a competitive tractor without going broke doing it Thanks
hat's a bit of a stretch never run with it? i believe it would beat a moderate 77(quoted from post at 19:01:32 02/01/14) there's not much room in the 30 block and you will never make one run with even a moderate 77 build, in 4500 and up you might as well build an 88
oh wow im impressed with your name dropping wheres yours at you build one then i will build a 550 and drag your azz with that herc.on second thought i wouldnt even need to build a 550 i just run mine stock :wink: thats a little closer comparison troll(quoted from post at 02:48:42 02/02/14) a moderate 77 build to me is 4" pistons and an extra inch of stroke , you go ahead and build a 30 that will run with one and then after you beat that you can take on Norbert Bremmers 77 "Blue Blazes" and see how that goes! His is about the nastiest 77 I have ever seen.
