Rear Weights vs Fluid
1970-1655
Looking to change tires on a 1650 with 18.4-34, tubeless. Don't need weight all the time, just when moving snow and things. Which would you prefer, fluid in the tires or bolt on wheel weights? Which would give better traction on packed snow? Fluid would probably add about 2,000 pounds which would mean a lot of wheel weights to get the same weight. Or I could make a belly weight bracket and use hang-on weights in front of the rear tires.
How about just a weight for the 3 point or don't you have one? With that,you could just trip the latches and pull the center link pin and drive away from it. Fill a barrel full of concrete.
put tubes in the tires and fill with fluid. You will forget it is in there. Do you have new rims on the tractor, Unless you have new rims it may be hard to get the tubeless tires to seal up on old rims, they were made for tube type tires. You might be able to get them to take air with a lot of Murphys tire mounting compound smeared on the rims.
Fluid put the weight on the tread so also right to the ground no air cushion. Wheel weights puts weight to the ground by way of an air cushion so not near as good in my opinion
with the high cost of fuel I would use weights that I could remove when not needed and the easiest would be the belly bracket. Chuck
i think i would avoid the belly brackets seems to me you would lose some ground clearance ok for pullers but i wouldnt have them on a chore tractor
dont add weight to the frame or front unless you need it , it just causes ware on bearings and such , when you add fluid or wheel weights it dont stress the tractor because its sitting on the ground not on the tractor , and in all my years ive never heard someone say dont add wieght because of fuel use thats just crazy , a tractor is ment for hard work do you think it cares about some extra weight that rolls on the ground , i dont think so , if your pulling a plow , thats differant story that uses fuel not rolling weight
why do you think they are shaving weight off cars and trucks now days? i tell you for better fuel economy no other reason. the more weight you have the harder the engine works thus using more fuel. put two 2lb. weights on your legs and see how much more "energy" you use
2nd weight anywhere puts more stress on bearings and such because it still more mass to move no matter where you put it may be distributed better in certain areas such as fluid in tires but none the less those bearings still take more stress moving that extra weight. not an astronomical amount of fuel savings but with fuel prices every bit helps
Gears maybe, and brakes, clutch linings etc. All due to the
increased inertia (or momentum, when rolling).
You could put ten tonnes on each wheel and the wheel bearings
will still only need to bear the weight of the tractor frame
Wheels and tyres might not like it, mind!
All dependent on being a balanced load at the bearings, of
course. Like wheel spacers were never the proper way to widen
the wheel track, to fit oversized tyres to cars back 40 or 50 years
ago!
Of course there are but they are designed for the loadings
applied by the engine power. There is no power supplied by
heavy wheels to the gear train, only radial and axial loadings to
the half shafts or whatever. Think here basic engineering
principles.
