Anyone have Oliver 1650 Hydraulic Schematic?
ShepFL
Could not find one in the archives. Found a 1610 loader for my 1650. I understand to take it easy as the tractor could break the loader.
I am wanting to run both loader and rear hydraulics i.e. implement. Have conflicting info -
was informed I need a power beyond valve and others say not needed.
What say you Big Ollie fellas?
that loader on 1650 will be fine, ran one on 1850 for years and got along fine. you can hook them up aand still have valves open in rear. did it that way when i had 1650 also. think it was one under left front side of seat and other was in right side rear area. been long time now thou. i know ther was a plug you took out that is in the housing.
So would something like this work for the loader and keep my my rear remotes open.
https://www.surpluscenter.com/Hydraulics/Hydraulic-Valves/Directional-Control-Valves/2-SPOOL-COMPACT-10-GPM-JOYSTICK-CONTROL-VALVE-9-7401.axd
Joystick Control Valve
Well it is rated at 10 GPM. That is a little on the small side of what your flow would be. Notice they said for small & compact tractors. Your PUMP is 20 GPM theoretical. You need to allow for the flow divider + some pump wear and even for that you would be crowing the 10 GPM and building unwanted heat.
Thanks sir - just got the owners manual and service manuals on CD. Got some reading ahead of me as this is my 1st big Oliver. I want this to be the main rig for chores etc. on 50 acres of planted pines.
