Vic DiMatteo
New User
I have a 1550 Oliver Diesel that sat for a while now will not start. I have plenty of fuel in the injection pump, but when I am trying to bleed the air out of the system I have no fuel pressure... even at at the pump. Fuel only runs out by gavity.. I have made sure the fuel shut is not stuck, everthing is clean etc.. While cranking should I be getting some fuel pressure? Its acting like the injector pump is not pumping anything to the injectors. Before condeming the injection pump is their something else I can check? I am not getting any fuel to the injectors. Thanks Vic
