TractorLinks.com
Show Parts for Model:
Re: 1550 oliver Diesel Injection pump?
mab570diesel
01-12-2014 15:15:08
do you have all of your injectors lines loose and throttle wide open when cranking to tryn bleed the injectors
Vic dimatteo
01-13-2014 15:12:43
 Re: 1550 oliver Diesel Injection pump? in reply to mab570diesel, 01-12-2014 15:15:08
Yes. No fuel pressure anywhere... not even a drip. Everything is clean, and I have plenty of fuel that shows up in the return lines, but none in the main injector lines. Pump shart is ok, I checked all timinig and injection pump marks and they are all good... I had it running last year, and it was running great. just shut it off and stored in the barn, a year later no go..
AL BAKER
01-14-2014 06:39:15
 Re: 1550 oliver Diesel Injection pump? in reply to Vic dimatteo, 01-13-2014 15:12:43
I see this VERY often in my pump shop. The new ultra low sulfur diesel, and even worse biofuel or home brew veggie oil will lock up pumps that sit for a extended time. Very common, but still a pain in the shorts. Pull the pump off and have a pump shop clean and reseal it. Should cost about $350.00 plus stand time. I would be glad to help you if interested. 231/757/0064
Vic dimatteo
01-14-2014 15:53:38
 Re: 1550 oliver Diesel Injection pump? in reply to AL BAKER, 01-14-2014 06:39:15
Thanks everyone! Al I would like to give you a ring to discuss. Thanks
