White 160 paint codes
Can some one give me the codes or point me in the right direction. Looking for the color of the tub and drivetrain, wheels and rims, and the sheet metal. This will be painted using PPG paint and clear coat.
Thanks a bunch guys
160 white.
Beautiful tractors guys.
For the 160, maybe the 155 too? Wjhat are the paint codes? Or can someone point me in the right direction.
Thanks
very nice 155 g1355 never seen tractor tires with white lettering howd you come up with those look preety cool or did ya just paint the lettering
They make actual white lettering title markers, look on the Internet, about $20 a marker depending on the brand and how good they are. it takes about an hour and a half to finish all four and make them look good. And it doesn't wear off fast either, its like paint but its not, it holds up almost as good as white lettered car or truck tires. I did it because tractor pullers sometimes have it and I think it looks good. Gonna do my g1355 after I restore it also.
Tire marker
I'd go right to agco dealer and buy paint. The dark is charcoal gray and can't remember the silver. Sure I still have a can if I look. Sometimes I get it mixed as diamond Vogel we seem to have good luck with there paint.
Yeah i like it. it will be the closest match, if you clear coat it it looks very good and cleans up very nice also.
Agco's is single stage verses your ppg which I bet was two stage. It's hard to compare the two really since two stage typically is much better.
What I do is buy the Agco paint, paint a sample, then take it in and have it computer color matched for the product line that I want to spray. I keep that code for future reference. Works well.
Your idea would be best if he wants to use ppg because the agco color will be right. Guess I should of thought of that. I just clear coat over it and it looks good for me. My MM might get something better since yellow doesn't cover as nice.
