TractorLinks.com
Show Parts for Model:
Re: cockshutt 550
welding man
01-10-2014 04:57:22
Are you sure valves are adjusted correctly and timing is correct? Good battery cables,etc.How much did you take off the Head?
welding man
01-10-2014 06:47:02
 Re: cockshutt 550 in reply to welding man, 01-10-2014 04:57:22
I have one in a 35 that I pull.It has had some modifications and it is a little tough to roll over unless you have a good hot battery. It has electronic ignition, and starts good if it spins over fast enough.Sorry I can't think of anything else right now. You may want to run a compression check just for fun.
mab570diesel
01-10-2014 05:48:20
machine shop did head id have to look at paper work as far as how much they shaved off cables are good and clean never messed with timing i left it where it was before head removal valves are correctly adjusted tried that several times just to make sure rake with it in the summer does good in warm weather
