oliver 77 diesal
The 77 be it diesel or gas did not come with a 3 point so you have to buy an aftermarket one and install it. So depending on what you buy as to how hard it might be to install. Me I built a 3 point for my Oliver 77 which is a 1950 gas and the hyd system works it just fine
(quoted from post at 10:30:23 12/14/13) pros an cons..also how hard is to hook up 3 pt hitch..thanks for input dewy.......
was told by a very knowledgeable Oliver man the three point off an 880 will fit my '51 88 but an oil plug hole would have to be re-located in the rear end housing. I would assume the 77 would be the same. The problem is FINDING one. Jim
