TractorLinks.com
Show Parts for Model:
1550 under the hood muffler
Banditfarmer
12-12-2013 19:58:24
Guys I figured that I would try to put this 1550 back like it was new or close to it. the muffler that is on it is not bad but its not the right one for a 1550 diesel utility. In the Oliver parts book the muffler is part # 160-907-A and no one seams to be able to cross it over to any thing any ware. The hood has been cut out to put the strait through muffler on it and I can weld this butchered up hole back up for the under the hood muffler to go back on. So the question is dose anyone out there know ware to get one of these under the hood mufflers for a 1550 diesel? Oh The ones for an 88 diesel wont work according to the Oliver dealership guys. Bandit
Banditfarmer
12-13-2013 18:36:02
 Re: 1550 under the hood muffler in reply to Banditfarmer, 12-12-2013 19:58:24
It looks like I might just have to make one for it. I wish I knew what the inside of one of those mufflers looked like, I think I could fab the shell and ends up but I don't know what to use on the inside. I guess it will be trial and error. Bandit
mike french
12-13-2013 08:08:18
Yeah good luck finding an original one. With a little work an 88 one will work.
chucksoliver77
12-13-2013 04:56:49
 Re: 1550 under the hood muffler in reply to cody meister2, 12-12-2013 19:58:24
Bandit, If you don't mind it being a little loud you can make a can with inlet and outlet flanges and come out the original hole. That's what I did on my 77. Just a thought, Chuck
dabot
12-13-2013 03:52:04
Been there, done that. All I can say is good luck! I couldn't find one.
oliver1755
12-13-2013 07:06:57
 Re: 1550 under the hood muffler in reply to dabot, 12-13-2013 03:52:04
Bandit, I had the same problem. I took a muffler for an 88 gas and took it to the muffler shop and had the inlet expanded some to fit the exhaust pipe from the manifold. I then had a pipe made that fit the outlet, and up through the hole. This pipe is smaller than probably normal, but it works pretty decently.
