I was out plowing tonight, with my 1650 Cockshutt, when I was almost at the headland, was in 2 gear, with the T/A, in high. The tractor started to lug down pretty good, put the T/A lever into low, and just like that, the tractor stalled. I re started the tractor the tractor, released the clutch, to have the tractor, stall again. I tried to put the tractor, into Neutral, but I couldn"t move the main gear shift.
What I was wondering, could the main gear shift, be stuck between 2 gears, causing the tractor, to stall, and not being able to shift gears?
Your help, is greatly appreciated. Thanks in advance, Bruce.
