TractorLinks.com
Show Parts for Model:
1952 Oliver 77 fuse block
Paul Gi.
12-07-2013 01:31:23
Restoring a 1952 77 having problems remembering where fuse block is mounted behind dash. Fuse block is hooked to a metal bracket with two rubber grommet holes for wiring. Picture of mounting location would be very helpful. Thank You in advance.
rrlund
12-07-2013 10:13:16
 Re: 1952 Oliver 77 fuse block in reply to Paul Gi., 12-07-2013 01:31:23
I think it hangs down off the right side of the rear gas tank support doesn't it?
Bison2010
12-07-2013 09:25:36
[quote="Paul Gi."](quoted from post at 02:31:23 12/07/13) Restoring a 1952 77 having problems remembering where fuse block is mounted behind dash. Fuse block is hooked to a metal bracket with two rubber grommet holes for wiring. Picture of mounting location would be very helpful. Thank You in advanceg][img]
[/img]
This is off a48 ,not sure if it is the same
OliverNate
12-07-2013 10:23:04
 Re: 1952 Oliver 77 fuse block in reply to Bison2010, 12-07-2013 09:25:36
I have a 51 and mine hangs in the same spot
Larry NEIL
12-07-2013 15:50:36
 Re: 1952 Oliver 77 fuse block in reply to OliverNate, 12-07-2013 10:23:04
On the '53 I'm working on now it hangs right in the middle of the dash. It is wired for two cylinder controls.
Paul Gi.
12-08-2013 04:20:41
 Re: 1952 Oliver 77 fuse block in reply to Larry NEIL, 12-07-2013 15:50:36
Larry do you happen to have time to post a picture of where yours is located on your 53.
Larry NEIL
12-08-2013 12:44:11
 Re: 1952 Oliver 77 fuse block in reply to Paul Gi., 12-08-2013 04:20:41
Sure Paul, I'll get it after church.
Larry
