Aftermarket canopy/roll bar?
I am painting my 1855 an would like to install a roll bar/ canopy. Are the after market ones well made? The pictures look like they don't include the heavy blocks that go under the axle. Does anyone have one that they like or don't?
Josh
Like hayes said go to saginaw. As far as i know they are built like the original. I believe you can still buy them painted but they are all white and to me that doesn't look right.
I have an original canopy from a 1755 that I won't sell but the box around the hydraulic levers was also different. The roll bar sets into a factory indentation in the back. I don't know if anyone makes this hydraulic lever enclosure that allows the canopy to fit. You could just cut a notch but it wouldn't be like the factory one.
Saginaw will either make it the original width an you can notch your hydraulic cover, or they make it a little wider so it will clear it.
Josh
I put one from a 2-85 on our 1855 and our hydraulic lever cover was factory notched, so no mods were needed. I don't know if there is a difference between early and late model 1855's but ours is a late one.
Donovan from Wisconsin
