belt pulley delete question Super 88
Dodgeit
Want to remove the complete assembly, and replace it with just a cover. In looking on line what I've found is a cover that just goes around the shaft, and not the rest of the stuff that is covered when the belt pulley assembly is mounted. Is everything left open or am I missing something?
Any one have pics of a tractor with belt pulley delete?
Thanks
(quoted from post at 13:21:00 12/06/13) Want to remove the complete assembly, and replace it with just a cover. In looking on line what I've found is a cover that just goes around the shaft, and not the rest of the stuff that is covered when the belt pulley assembly is mounted. Is everything left open or am I missing something?
Thanks
Remove gear and flange, will need a pipe plug, and gaskets, and lip seal for housing. Korves has all parts, and might find used too
I have to remove my gear yet, but a pic is worth a 1000 words
Thanks for the pics. Have the parts from Korves, and made plates to block all the holes. Next is to set the engine back in.
