TractorLinks.com
Show Parts for Model:
Re: 2150 Project Bosch Pump Question
J. Schwiebert
12-04-2013 12:55:34
Maybe a word of caution. There was a 2150 around here with a pump off a DT 466 I think (maybe a 436). 200 horse no problem, cracked exhaust manifold no problems either. I put 2 pair of manifolds on there before they took the tractor to a dealer in another state.
Mitch Poindexter
12-04-2013 13:29:31
 Re: 2150 Project Bosch Pump Question in reply to J. Schwiebert, 12-04-2013 12:55:34
How were they handling the fuel shutoff?
J. Schwiebert
12-05-2013 08:38:53
 Re: 2150 Project Bosch Pump Question in reply to Mitch Poindexter, 12-04-2013 13:29:31
They used the hydraulic head from the IH and not the rest of he pump. Older IH trucks with the DT466 and a model 100 pump had electric shut off as well on some of them. What did A-C use on the 8000 series with the model 100 pump?
Dieseltech
12-05-2013 15:20:18
 Re: 2150 Project Bosch Pump Question in reply to J. Schwiebert, 12-05-2013 08:38:53
AC 8000 series used a spring loaded idle stop capsule like IH tractors did to shutdown with the throttle lever. The electric shutdown cover, solenoid assembly also needs a different fuel control unit, all very expensive. Another choice is the Bowden wire shutdown that the early trucks used if a complete cover assembly can be found. Will bolt right on and work with the control unit in place now.
