1800c diesel fuel tank
hd6gtom
thought I posted this earlier today but must not have. I need the fuel tank that goes under the hood. Mine has rusted out on the bottom and I see its been fixed before, post back if you have 1 for sale, I'm in south central Iowa. Thanks Tom
Tom- I got one out of an 1850 gas here- email me if your interested- its open. I"m located in SE Minnesota- an hour and 10 minutes north of the border.
does anyone know if either of these tanks are the same as mine? Mine has two holes in the bottom one has the fuel shutoff in it the other has a tank drain valve in it. Fuel fill hole is on the left side of the tractor hood.
I just had to check on another item for an 1800. My parts book shows the same tank for all 1800 diesel tractors. The gas models never had the water trap so they used a different tank. I will not be able to check the 1850 gas tank till in the A M. It will not have a water trap. More questions? J.
I have a 1850 diesel tank. Not sure if they are the same. E-mail me if interested. I am in nw Iowa. 30 miles south of Worthington, Mn.ph. 7 one two 7 two nine three two four eight jps
Way easier to replace the whole tank,but I cut out and welded on a new bottom on my 1650 diesel tank.Added a 2" drain to it.Was'nt that hard.
Well I didn't see my 1850 PARTS BOOK, I think we have it at work however I checked a 1750 parts book and that tank is the same as on the 1800 so I think the 1850 diesel tank is the same. Can check in a day or 2 if you me to.
