310 camshaft specs needed
bison
I'm in the process of rebuilding a 310.
The camshaft lobes are somewhat worn me thinks but i don't know the original specs.
highest lobe measures 1.4185 with calipers across the shaft or with a straightedge held against the bearings it will pass a .128 feeler gauge between the lobe and the straight edge.
Lowest lobe(only one) has a across measurement of 1.3680 or a full .425 shorter than the highest one :shock:
If i need an other camshaft,...were to get?
Also looking for 2 rods.
Thanks
Yea I can look the dimension up in the morning. Also remember if this is for a diesel they came out with a little "improved version" The dimensions I will give you will be for lift.
(quoted from post at 16:45:04 11/17/13) Yea I can look the dimension up in the morning. Also remember if this is for a diesel they came out with a little "improved version" The dimensions I will give you will be for lift.
Yes this is a diesel.
Thanks
