can you make a 1950gm fwa sit level?
johns
All the Oliver 1950gm FWA"s I see squat in the back. Is there a tire combination that will make the tractor sit level?
I'm pretty sure that's how they all were, even the plain 1950s were, I'm sure if you'd put 42 inch rubber on them they'd sit level or down in the front a bit, but probebly gonna run into fender clearance problems, guess you can always put smaller tires on the front.
