1655 Diesel Engine Numbers
I just got a 1655 Cockshutt with an engine number 221-620 / 166425. This is the same as the number on my 1855 gas with 310. I wonder if someone put a 310 in it.
Those are CASTING numbers. They used the same block to build both a 283 diesel and a 283 gas and a 310 gas. I need to check but later 310 diesels used a different casting number
The ill fitting motor to bell housing was what made me suspicious. I took the bolt out and the plate ear is broken off. That's why the big washer. I will need to find a new plate and bell housing. The bell housing ears are welded. Maybe the motor is right.
Nice lookin pair of units you have there. I'm green with envy. One day I wouldn't mind seeing your collection up close.
I wish I could keep more of them but my budget is pretty limited. Whenever I buy something I have to sell something. I need to get rid of some of the non-Olivers to be able to keep more four digits. I have 11 Olivers and Cockshutts right now and I have more in sight. A couple of those are parts tractor.
