34 inch rims for 990
18.4 x 34's are stock tires and 23.1x26 is the other. Id say they are quite common and should be not to hard to find. Any super 99 990 and maybe other olivers may be the same. Hopefully some other guys will fill in the blanks some more. Duane o.
Do you have some stock 34" cast centers? What kind of hubs are you running to get the 38s to fit the stock tapered axle? The stock rims are a single bevel, and are somewhat difficult but not impossible to find. The rims on my 990 were rotted from having fluid in the tires and I was able to find some rims off of a Moline GB which were the same single bevel. A double bevel will not fit the stock cast centers right.
switched the 34"rims off my oliver 2655 for 38". my hired hand needed rims for his ih w9 and they fit. same as oliver99
Early 990's had the same rim as the s99 later ones used a generic rim. I'm guessing you have pressed steel rims instead of hubs though?
I took the 1500 lb hubs off and put some hubs off a 99 on my 990. Had to take tires off and turn rims around and relocate vale stem to make them work.
990 was 12,600 lbs and I wanted to get to under 10,000 lb class. Now I"m adding weight as I was 8,496 lbs with no fluid in tires. All bolt on and hanging weights. thinking 34" rims will gear down enough to pull in 3rd.
Thanks to all for your feedback. I bought 3 WD9"s this year so will be getting my brother and nephew hooked. LOL
Curt
Are the rims on a WD9 the same as a W9 ??
I like the idea of 2655 Oliver 34" rims if they will fit.
I measured my super 99 hubs that I installed looks like 29 1/2" they are probably 30" but had to use flashlight and tape measure. LOL
TIA: Hemi
Broke the railway rail I was using as part of my puller. Then I went and got two pieces of 2"x3" steel 2" thick and finally after "big pressure" they came loose. Just about browned my shorts. LOL
