1850 gasser 3-point
cjackman
Hi all, have a 1850 gas and have a problem with the 3 point. When plowing the right side (if looking at the rear) lift arm walks out of the tractor. I can tap it back in and will go for a while but worries me. Don't wanna ruin something. Any suggestions?
there is a squeeze clamp coupling/draft sensing link that holds both of those shafts together in the middle. it may have come loose or snapped a bolt. drop the rear end oil pull the live shaft and then the rear pto unit and you will see four bolts on that clamp if I remember correctly. that is the only thing that holds the lower rockshaft in place
