TractorLinks.com
Show Parts for Model:
Re: oliver 77 rc gas hydraulic pump removal
J. Schwiebert
11-06-2013 03:32:43
Make sure you take the long PTO shaft out first, I never used ANY SPECIAL TOOL. Take the gear shift off, BUT after you take the 2 bolts out and as you lift the gear shift up slightly stick your fingers under there to hold them in place. Use grease to hold them in place when you re-assemble the unit. Make sure the tractor is in neutral to aid you in the reassembly. Get 2 small 3/8 inch set screws and place them in the corners of the gasket when you reassemble the unit to hold the new transmission gasket in position
