Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: sixth gear growl in a 550
10-31-2013 09:19:32
Quoting Removed, click Modern View to see it probably has straight cut gears, which are naturally more growly and loud than helacial cut gears, later on tractors adopted the use of helacial gears to reduce noise, i think it would be fine, my grandpa's 770 really growls and its fine
J. Schwiebert
10-31-2013 11:50:00
 Re: sixth gear growl in a 550 in reply to blue924.9, 10-31-2013 09:19:32
All Super 55 & 550 tractors used helical gear transmissions
10-31-2013 12:29:15
 Re: sixth gear growl in a 550 in reply to J. Schwiebert, 10-31-2013 11:50:00
i wasnt sure, thanks for correcting me, then the gears are probably wore out, i am most familiar with allis chalemrs, and a way to test them to see if they are wore is to put it into that gear and put a load on it, then open it wide open and slam the throttle closed, you could try that. otherwise the way to know for sure is to crack open the trans or remove the inspection cover (if it has one, i know my wd does) and take a look for yourself
