Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: rrlund - 1365 loader hydraulic pump question
rrlund
10-29-2013 13:26:59
That pump is listed on Import Tractor's web site. It says they are a replacement and not intended for tractors that never had them.
Mine has the reservoir in the loader frame,yes. I think you can see the fill plug and filter OK in this picture.
I've got a close up of it before I painted it showing where it mounts above the PTO.
Mitch Poindexter
10-29-2013 13:56:02
 Re: rrlund - 1365 loader hydraulic pump question in reply to rrlund, 10-29-2013 13:26:59
Thanks. Mine has the mounting plate back there with the hole in it for a pump, it has apparently had one at some point in its lifetime, so I think I'll only need the pump itself. Do you have to have the engine rpms up pretty high to make the loader operate well, or does it run good at lower rpms as well?
rrlund
10-29-2013 14:06:01
 Re: rrlund - 1365 loader hydraulic pump question in reply to Mitch Poindexter, 10-29-2013 13:56:02
It'll squeal the relief valve at around 1100 RPMs I generally run it around 1200 when I'm loading.
Copyright © 1997-2015 Yesterday's Tractor Co.
