1550 Diesel Hydrapower
Chief 83
OK now that I own one what the good, bad, and ugly on this tractor? Planning to use it to pull a small square baler. Less than 50 acres per year.
the pto is slow compared to the engine rpm on an Oliver which makes them pull a heavy load good like a forage cutter but you have to run the engine fast on a baler so we baled with the Case's instead
