TractorLinks.com
Show Parts for Model:
Re: 550 Oliver
90 Percent Retired
10-20-2013 14:54:15
On most valves of that type, the spool and valve body are a matched pair, and not repairable, only seals, "O" rings and springs can be replaced. My only suggestion is to remove the end cap, opposite the handle end, and check for rust, and corrosion of the centering spring as that could cause the spool not to center and not let it (the spool) move far enough to allow normal lowering speed. Otherwise just replace the valve. What you need is shown on the link below.
http://www.northerntool.com/shop/tools/product_200311691_200311691
This post was edited by 90 Percent Retired at 14:55:14 10/20/13.
