Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 550 Oliver
Wayne Six
10-20-2013 13:49:23
Certainly did not mean to offended anyone. Tractor and front end loader has always and is still going up just fine, no twisting or jerking, etc.... Mr. Lund was pretty clear that there was no way that it could work at all the way it was plumbed with the type of valve he presumed it to be. It has been getting worse and worse about going DOWN over the years but still goes up, and lifts huge loads, just fine. So reading all the comments....my thought was I may well have two problems...the quick disconnect may be in backwards. Got it at Tractor Supply and do not recall seeing any sort of installation directions/guide..seems like it may have been the last one and stapled shut if I remember right...if it is and when I reverse it, it starts going down again...really, really slow like it was before it stopped going down at all....well, strikes me the next step would be getting a rebuild kit....and if that does not work, probably replace the controller. Just my thought process....certainly didn't mean to appear to be unappreciative...again, my thanks to all and my apologies to anyone that has taken any offense.
fixerupper
10-20-2013 17:31:03
 Re: 550 Oliver in reply to Wayne Six, 10-20-2013 13:49:23
Wayne, you can buy a swivel fitting to put in there in place of the Pioneer coupling if you have a hose that doesn't have swivel ends. It's just a little fitting with male threads on one end and female on the other and it swivels. It's cheaper than a Pioneer, gives a lot less trouble, doesn't impede flow, and it isn't prone to dripping and leaking. Jim
edit; I looked at the pic of the valve again and there is a swivel at the valve on one of the hoses coming up from the pump/reservoir. Get one of those and put the Pioneer coupling on the shelf somewhere. I still can't figure out how that thing works if it's plumbed at the bottom of the cylinders the way I think it is.
This post was edited by fixerupper at 17:51:56 10/20/13.
90 Percent Retired
10-20-2013 14:54:15
On most valves of that type, the spool and valve body are a matched pair, and not repairable, only seals, "O" rings and springs can be replaced. My only suggestion is to remove the end cap, opposite the handle end, and check for rust, and corrosion of the centering spring as that could cause the spool not to center and not let it (the spool) move far enough to allow normal lowering speed. Otherwise just replace the valve. What you need is shown on the link below.
http://www.northerntool.com/shop/tools/product_200311691_200311691
This post was edited by 90 Percent Retired at 14:55:14 10/20/13.
