TractorLinks.com
Show Parts for Model:
Re: 550 Oliver
pete 23
10-19-2013 11:11:38
Like the man says, single action cylinder have to be run off the same outlet of that valve. T them together. Some control valves similar to that one have a plug inside them you take out when using it on single action cylinders so the pump is not dead headed (working under pressure) when you lower the cylinder. If that plug is out then you would not build pressure in that direction and that might be why it seemed to work hook that way at one time. Anyway, hook both cylinders together on same hose and let her rip.
