TractorLinks.com
Show Parts for Model:
Re: 550 Oliver
fixerupper
10-19-2013 10:13:18
One thing that comes to mind is that valve might be an old three way valve, meaning only one port has pressure and the other is return only. IF it is a three way valve the cylinder hooked to the 'return' or forward port on the top of the valve never did do anything. I have one of those old valves in the store room and it looks physically just like this one in the pic.
Edit, maybe I should add if it's a three way or single acting valve the front port should be plugged. It should be plugged if it's a four way (or two way, whatever you want to call it) valve the front port should also be plugged, usually a 1/2" pipe plug will do the job. if you don't plug it you'll shoot oil up into the sky when you push the lever ahead. Jim
This post was edited by fixerupper at 13:19:26 10/19/13.
