TractorLinks.com
Show Parts for Model:
Re: 550 Oliver
rrlund
10-18-2013 12:46:28
Wait a minute. If you read what I wrote before I edited it,don't pay any attention. I looked at the picture again,that was all wrong. I honestly don't see how that ever worked. And you say it did though?
What's happening there is that if you have single acting cylinders (no down pressure,one hose to each cylinder and only at the bottom),when you raise it,you're putting pressure to one cylinder,then when you try to let it down,you're putting pressure to the other.
You need to put a pipe plug in the top port closest to you and a pipe T in the other and plumb it so both cylinders are getting oil from the same port. Hook both hoses to the T. You don't need a return to the valve,when you push the lever it will let the oil from the cylinders back in through the valve.
This post was edited by rrlund at 12:54:32 10/18/13.
