Paul Vander Byl
New User
Any tips on diagnosing the new noise I have on my white 2-60.
I think it may be a bearing on the input shaft or clutch bearing. I also noticed at the same time the bushing on the clutch pedal is gone..
Worse when warmed up/hot.
When not moving:
- Disengaging clutch will make it go away.
- Higher RPM with clutch engaged will also make it go away.
Do I need to split the tractor to change bearings in tranny?
When not moving:
