perkins serial number
terrywh
i bought this motor today for my project the numbers on the pad are 354ua17372t
i wanted a blabk motor but could not find one that was very cheep i found a guy that has the harmonic balancer thanks
Perkins used 3 different serial number set ups. The early system was a 6or7 digit number starting with the number 8. In 1966 they went to the system like you have where the 354 indicates the size of the engine and the next letter U in your case indicates it was made in England. Right now I am trying to remember the letter A as Oliver did not use it. Then they went to the build number system. This is all going by memory. I used to have a little book which had that information but spilled battery acid did it in. More questions let me know I will search my memory more.
