Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 77 diesel crack on cylinder head
J. Schwiebert
09-22-2013 13:04:26
I would worry if there was NOT a crack in the head. If you look you will find more. I don't know you took the engine apart but get seats put in the head so you can set the valve recession to the correct specs. It will improving starting. More questions, post aphone number. J.
matthies
09-22-2013 19:38:45
 Re: 77 diesel crack on cylinder head in reply to J. Schwiebert, 09-22-2013 13:04:26
Thanks for the reply, I told him its common at least on the older diesels, he did a compression check and most were 175 but one had 225, 225 is what local oliver guru told him what it should be. Will pass your information to him tomorrow. chris
J. Schwiebert
09-23-2013 03:47:08
 Re: 77 diesel crack on cylinder head in reply to matthies, 09-22-2013 19:38:45
You need at least 100 pounds more compression than your 225! How did you check the compression?
matthies
09-23-2013 07:40:30
 Re: 77 diesel crack on cylinder head in reply to J. Schwiebert, 09-23-2013 03:47:08
I'm sure he used a rubber tipped hand held tester. chris
J. Schwiebert
09-23-2013 07:44:55
 Re: 77 diesel crack on cylinder head in reply to matthies, 09-23-2013 07:40:30
That is not how you do a diesel! Do you have a phone number?
matthies
09-23-2013 12:57:12
 Re: 77 diesel crack on cylinder head in reply to J. Schwiebert, 09-23-2013 07:44:55
I know about testing he used what he had on hand. If you want to call one 4o2 six4o oneseven0seven.
