Oliver Super 55 Transmission Gears
05sonicblue
New User
Since I bought my tractor I couldn't get it out of the high set of gears and all of a sudden last week, it started making a noise so I decided to take the transmission cover off. Once I off I noticed that a tooth broke off of one of the gears. I need to try to find a replacement gear or a full set of gears. Any ideas on where I could get these? Are these gears pressed on? Also, can I take out just the top set, or do I also need to take out the bottom set? I also will need to get new gasket for the transmission cover. Can this be purchased individually?
No disrespect to Ken, he has helped me in the past, but I have most of the gears for the tranny. There should be a part number embossed into the side of the gears or look on the Agco website. When you know what you need I can go though mine and see if I can help.
Rich
You are also going to need a manual and depending on which gear you may need to do the Z split of the tractor. Also a serial number is going to help and you will need to know if you have the 518 or the 519 gear code. Also are you close to an old Oliver dealer? You will need to borrow or make a couple of spanner wrenches to help in the disassembly. My 2 cents worth J.
