1650 power steering lines?
My 1650 had a power steering line burst just below the steering motor inside the dash. There are a cluster of 4 lines. I have the tractor tore down and have found the one that's bad. Since I have it this far, I was thinking of changing them all. The line are 1/2 steel,1/2 rubber so the steer wheel can tip. I called to check with dealer to get price. $150,+ per line. My question, is it possible to have the lines made like for hydraulic or do they need to be ordered? Thanks, Brad
I have them made with a pressed on compression fitting on one end. Then I cut the steel line off the old one,slide it in the compression fitting and tighten it up. Those stock ends might be available somewhere,but not something you're gonna get put on at the auto parts store. The ones that go in the hydramotor are standard and easily available but the other end isn't.
I found a business that sells & fixes ag & construction equip. They were able to use the steel part of old line, with a compression fitting and a new rubber end. I think I'll be back in business, just didn't have time today to put back together. Thanks. Brad.
