TractorLinks.com
Show Parts for Model:
Re: 1755 hydraul drive unit moving
ollie gm
09-14-2013 09:53:10
Right now I would say your only problem is a mis-aligned coupling. I would shim the engine mounts until the alignment is good then most likely you have eliminated the movement. Your PTO hub should still be centered OK.
I worked on a 1855 where the owner had forcibly "slugged" the PTO shaft into its final position and the result was a destroyed PTO hub. The end result was the hub being off center which really made a racket when running. I had this experience in the back of my mind when I was referring to your problem.
Good luck.
goatfarmer
09-14-2013 10:38:56
 Re: 1755 hydraul drive unit moving in reply to ollie gm, 09-14-2013 09:53:10
Thanks. I now understand your concern. I didn"t "slug" it into position, but tapped it because the thought was "new" into "new" might be a tight fit. I was able to get it out with out too much trouble. Will try shimming it. Thanks.
J. Schwiebert
09-15-2013 17:22:16
 Re: 1755 hydraul drive unit moving in reply to goatfarmer, 09-14-2013 10:38:56
Give me a call Monday night.
