Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1755 hydraul drive unit moving
goatfarmer
09-13-2013 19:42:51
I was able to pull the shaft and cranked the motor. It still moves, but not as bad. I think I need to remove the chain from the coupler and crank. How does the PTO hub get off center. It is bolted to the flywheel? If it is off center, how does one get it back on center? Or are you saying it isn"t on "center" to begin with because the engine may not be leveled?
ollie gm
09-14-2013 09:53:10
 Re: 1755 hydraul drive unit moving in reply to goatfarmer, 09-13-2013 19:42:51
Right now I would say your only problem is a mis-aligned coupling. I would shim the engine mounts until the alignment is good then most likely you have eliminated the movement. Your PTO hub should still be centered OK.
I worked on a 1855 where the owner had forcibly "slugged" the PTO shaft into its final position and the result was a destroyed PTO hub. The end result was the hub being off center which really made a racket when running. I had this experience in the back of my mind when I was referring to your problem.
Good luck.
goatfarmer
09-14-2013 10:38:56
 Re: 1755 hydraul drive unit moving in reply to ollie gm, 09-14-2013 09:53:10
Thanks. I now understand your concern. I didn"t "slug" it into position, but tapped it because the thought was "new" into "new" might be a tight fit. I was able to get it out with out too much trouble. Will try shimming it. Thanks.
J. Schwiebert
09-15-2013 17:22:16
 Re: 1755 hydraul drive unit moving in reply to goatfarmer, 09-14-2013 10:38:56
Give me a call Monday night.
Copyright © 1997-2015 Yesterday's Tractor Co.
