Anything remove / dissolve Permatex gasket sealer?
Alan K
Anyone know what will dissolve or remove permatex gasket sealer? It is in a hard spot to get at so I cant use a wire wheel or wire brush.
W-40 will soften it up.
I usually use an old wood chisel to scrape it off,might have to sharpen it a couple times(be careful on aluminum)
Permatex gasket remover does a great job.
But please,use with caution, had a drop of the spray on gasket remover get splashed on the plastic lens of my glasses and it melted a spot on the lens in a second.
But it did a great job on removing the old gasket.
