550 diesel line leaks
sam p
New User
bosch pump lines leak at head assembley, also small drip at delivery cap. runs very good but needs help to start.Best way to stop leaks.Any knowledge would be appreciated.thanks
Did you try to tighten the lines? If not loosen the lines one at a time and see if the fuel will wash the dirt out. Do you have an accurate torque wrench. You may want to anneal the copper gasket under the delivery valve cap and tighten it to the correct torque. Tell us more about your starting problem.
