waukesha help
walkintall
New User
hi, i'm looking to turn my 310 loose out of my 1800 and put it in a 1950T for stock pulling. the motor runs strong and was recently rebuilt (can be seen by searching "cockshutt 1800") can anyone tell me if the injectors are different in the turbo application? am I looking at just changing tips or something simple? as well how much should my pump go up?
thanks alot
What cylinder head are you using, direct injection or energy cell? If direct with pencil injectors the turbo models did have slightly larger holes. If energy cell the stock DNOSD21 tips will most likely flow enough even with the pump cranked up some.
