Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oliver 550 Possitive Ground starting problem
08-29-2013 00:21:06
Which terminal did you jump to on the solenoid? If the feed side, your connection from the battery to solenoid is poor.
If it was to the starter motor side it could be the above, the solenoid or the ignition switch feed to the solenoid which is the fault
08-29-2013 00:27:38
 Re: Oliver 550 Possitive Ground starting problem in reply to oliver90owner, 08-29-2013 00:21:06
All, of course, expecting the 'jump wire' is like a battery jump lead and not an 8amp sized connector.
If the wire is only the small section it will be a fault in the solenoid energising circuit - from battery to switch to solenoid.
