Oliver 550 drat control
Anonymous-0
Can anyone help me locate the screw to lock out the draft control on a 1967 550. I need to use a post hole digger and it makes the draft control bounce like crazy in anything but full up or full down position. Thanks
Where is the top link connected to the tractor? Use the bottom hole to make less sensitive to draft. Does your tractor have adjusting bolts next to the seat mount on the top link bracket?
I have the hole digger mounted in the bottom hole. Not sure about the bolts, I can't identify any bolts that look like they would hold the draft.
With your description in mind I looked again and found the two bolts. I backed them out till they contacted the seat bracket and no more bounce. Thanks for the help.
