Show Parts for Model:
Jerod Riha
08-27-2013 10:18:35
Does good old Agco still have available the steering pins and bushings and the joint pins and bearings available for a 4-210?
Jerod Riha
08-27-2013 17:27:24
 Re: 4-210 in reply to Jerod Riha, 08-27-2013 10:18:35
Thanks guys I will try John Deere!!
08-27-2013 16:48:19
As mentioned check with Maibachs. If you have a local JD dealer check with them as well. JD model 8440 or 8640 should match.
08-27-2013 12:13:35
I'm sure they do, if not I'm sure you can find a John Deere on international 4wd that used the same pins and bushings. Most white parts you can get espicially if your patient, give your dealer time to look around.
08-27-2013 11:06:10
I registered on the Agco parts online website.
Used Maibach for a dealer. Does not take too long to do and has saved me quite a bit of time and aggravation.
Larry NEIL
08-27-2013 18:33:19
 Re: 4-210 in reply to Cas, 08-27-2013 11:06:10
Well, it's been about 7-8 years ago, but I got the pins I needed to rebuild my 4 180 from AGCO.
