Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Oliver 1650 electrical issue
cb in wisc
08-27-2013 09:39:29
Wow, I am having the same problem, only I have a diesel. I am getting 10+ volts when testing between ground and the starter. There are two six volt batteries on this tractor and when I tested them I was getting over six volts on each battery. I see on the wiring diagram there is supposed to be a safety switch, but I haven't found that yet.
08-27-2013 11:31:05
 Re: Oliver 1650 electrical issue in reply to cb in wisc, 08-27-2013 09:39:29
The safety switch is under the transmission shifter cover. If you look at cover from the right side of the tractor you should see 2 wires with plug in terminals that will connect to 2 wires coming out of the wiring harness. In neutral you should have continuity.
