The key item on the injector is the tip assembly. IF the engine is the same as the Oliver engine the injectors are the same as any older Oliver diesel. Prices vary and any good diesel shop can fix you up. Older Oliver engines used injectors made by American Bosch. Later ones used injectors made by CAV. The tips are the same and most likely will be made in Japan. NOW here is the key item: You say it is a 302 Waukesha. Is it like an Oliver engine or is it a genuine 302 Waukesha? The real Waukesha does not use the same injectors as the Oliver engine. My first question: Are both the intake and exhaust manifolds on the same side of the engine? More questions? j.
