TractorLinks.com
Show Parts for Model:
Re: Hydraulics on 77
J. Schwiebert
08-26-2013 03:05:42
Well first of all is the tractor equipped with a mechanical lift to operate the cultivators or is it a hydraulic unit? Hydraulics can be added if it has a mechanical lift.
RCP
08-26-2013 05:06:15
 Re: Hydraulics on 77 in reply to J. Schwiebert, 08-26-2013 03:05:42
J
I thought the input shaft was different and would have to be changed to run hydraulics in place of the cultivator lift?
Rich
J. Schwiebert
08-26-2013 11:53:46
 Re: Hydraulics on 77 in reply to RCP, 08-26-2013 05:06:15
That is correct. You can cut them off
jordan hackman
08-26-2013 09:53:37
they are not different all you do is take out the pto shaft, take off the rollamatic or the empty slot and put in the hydraulic unit. however some things need to change, if the area never had anything there is a plate that blocks the pump. also if there was nothing there before the hydraulic unit the shifter lever from the empty slot doesn't work with the hydraulic unit base plate, and i don't know if the lever from a rollamatic is the same or different from a hydraulic shifter lever.
J. Schwiebert
08-26-2013 11:56:19
 Re: Hydraulics on 77 in reply to jordan hackman, 08-26-2013 09:53:37
You said: also if there was nothing there before the hydraulic unit the shifter lever from the empty slot doesn't work with the hydraulic unit base plate. The shift levers are the same. The socket the shift lever sets in is different. The one for a hydraulic unit will have an A behind the casting number.
RCP
08-26-2013 11:21:33
Korves lists different input shafts for hydraulic versus cultivator lift on the 77 and 88 tractors.
Rich
J. Schwiebert
08-26-2013 11:57:31
 Re: Hydraulics on 77 in reply to RCP, 08-26-2013 11:21:33
A & I also has them. See my answer above.
