waukesha 302 Injectors
jdchevy
I have a 302 that we have been tractor pulling with, it needs pump work and injectors. Do the pumps or injectors on this motor interchange with any other motor? we"re looking to pick up a spare pump. It has the American Bosch pump. Or does anyone know where to get new injectors.
same Injectors as a 88 motor, but the pump from the tractor on the 302 ci was goverened at 1800 instead of 1600 for the 88. I put a roosa master pump on mine last winter (off late 1650-1655) must change the front plate and cover, gear, and lines. it starts lots better with the roosa master pump
the nozzles any compitent diesel shop could test and rebuild,i run the bosch pump on mine it would out pull alot of gas tractors of same size getting more air in these motors is the key to power not on the fuel side , bigger valves and head porting will get you a little more horse to play with
