Hercules Go-130 engine
johnsnga
New User
Does anyone have engine specs for 1958 hercules go-130, would like to know plug gap, point gap, timing, etc thanks for any info you can give
Thanks for your help, I can all ways use all the info I can get, a phone number would be helpful, thanks j
Well the plug gap I will need to look for in another book. What is the application for this engine? If it is in an Oliver OC-4 then the timing is 29 degrees BTDC @ 1700 RPM. Valve setting is 010-011 HOT on both the intake and exhaust valves. If the engine is not in an OC-4 (Power unit) I need more details. More questions send me a phone number. J.
Thanks j it is in a 1958 oliver crawler oc4-42-3g serial 1wr-196 engine is go-130 serial 3750019? Badge is wore but im pretty sure this is correct. Cell# is 423-290-8567
