320 engine in 88 chassis
dwoliver
New User
Would like to have info on 320 or 195 walk engine in 88 chassis. info on carb linkage, clutch assembly, water pump and fan clearance to rad. etc. If you e-mail me your phone number and good time to call, I will return your phone call. Thank you DW.
Remember the 320 engine is the same basic length as your 88 engine. You may want to use your 88 water pump. Do you have a set of casting numbers for the block? What were you thinking clutch wise organic or button?
Could you E-mail me your phone number and a good time to call you. I think you know a little more about this subject than I do. Thank you Dave.
A 88 pump is way different than a 99 pump ,radiator necks will have to be adapted to fit Use
What parts will work to make fit easy bolt in 6182466030
