TractorLinks.com
Show Parts for Model:
Re: Super 55 Transmission Issues
Dick W.
07-31-2013 12:32:13
I have done the shift lever removal several times on my 55 and Dad's 70. It is easy to remove and than just get the shift forks into neutral, re-install the lever into the proper slot, good to go!
You may need a long sturdy screw driver to move the shift forks to neutral. You will see all 3 forks lined up when there is an open spot on all 3 next to each other.
elcajonfarms
07-31-2013 15:36:45
 Re: Super 55 Transmission Issues in reply to Dick W., 07-31-2013 12:32:13
OK--I'll give it a try. Thanks
Dick W.
07-31-2013 17:45:37
 Re: Super 55 Transmission Issues in reply to elcajonfarms, 07-31-2013 15:36:45
Don't let the springs fall into the trans!!!!!!!!!!
elcajonfarms
08-27-2013 14:07:34
 Re: Super 55 Transmission Issues in reply to Dick W., 07-31-2013 17:45:37
Once I took a close look at the I&T shop service manual and got a clear understanding of where the forks are, it took me two minutes with a 9/16 inch wrench and a 12 inch screwdriver to fix the problem--forks out of synch. Thanks for the suggestions.
